Clutch and various other maintenance questions?
Old Oct 2, 2010 | 01:43 PM
curtorous's Avatar
Default Clutch and various other maintenance questions?
I have a 94 850 non-turbo. has well over 200K on it (not sure how far as the odometer is dead). The clutch needs to be replaced. There is definately pressure in the crankcase causing a leak at the oil cap. and i will need to do rotors and pads as well as ebrake shoes on the back sooner rather than later. My questions... Is it worth the replacing the clutch? I could probably do this myself in the driveway but i dont really want to. Quotes for replacement are running anywhere from 900 -1500. Is it more likely going to be the 1500? and finally does any one know how to get the climate control fan speeds 1-3 to work?
Old Oct 2, 2010 | 02:41 PM
curtorous's Avatar
Default MCC resistor
Ok so i got unlazy and read through previous posts and found out about the mcc resistor sorry.
Old Oct 2, 2010 | 04:50 PM
stro1da's Avatar
clogged flame trap same as pcv valve will cause motor to build crank pressure
Old Oct 2, 2010 | 04:51 PM
stro1da's Avatar
never let a volvo die
Old Oct 10, 2010 | 05:42 PM
garypettengill's Avatar
Pressure in the crankcase is the flame trap. FCP Groten offers a kit which includes the intake manifold gasket.
Clutch change is pretty straight forward. You either take the engine/transmission out through the top or raise the car, lower the eng/trans down enough to seperate the two and pull the trans out. Did my 93 in my garage last year.
Old Jan 1, 2011 | 02:47 PM
curtorous's Avatar
Best advice I ever recieved on a car forum. I sprung for a pro tp do the clutch. I put four new snows on and a four wheel alignment. Drives like a new one. What a car. The more I drive it the more I love it.
mexicanfooddude
Jul 13, 2015 05:32 AM
marshcat
Jan 13, 2011 04:40 AM
Saleen9090
Feb 16, 2009 05:48 PM
nicolaselias
Sep 8, 2008 10:36 AM
pigoo3
Feb 20, 2007 03:49 AM
