Code 115, radiator fans runs high
Old Aug 12, 2006 | 12:38 PM
andydg's Avatar
Default Code 115, radiator fans runs high
Started my 97 855 this morning and the check engine light came on. Turned off the car, the radiator fan kept running. Plugged in my OBD reader, code 115 came on. From what the book tells me this generic code relates to the engine temp sensor. Is this the sensor located near the thermostat? The car has just under 140k miles on it.
Old Aug 12, 2006 | 01:16 PM
Default RE: Code 115, radiator fans runs high
That should be the sensor there at the thermostat.
But look at the thermostat as well. They are known to Break.
Old Aug 12, 2006 | 01:33 PM
andydg's Avatar
thanks, I'll probably change both while I'm at it along with the coolant. Time to change that anyhow.
sheli1014
Jun 4, 2014 12:00 PM
bcolins
2001-2013 model year V70
Oct 21, 2013 03:09 AM
dpjnicholson
Nov 12, 2010 12:08 AM
jdsmith
Dec 15, 2008 05:00 PM
barge
May 12, 2006 10:55 PM
