Code 222 Srs Light on
Old Mar 16, 2011 | 01:03 AM
Aftermidnight's Avatar
Default Code 222 Srs Light on
My Srs Light came on today and showing a code of 222 which is Passenger -Side Air Bag, Open Circuit. Car is a 95 850 T5 with 160k miles. Thoughts? Thanks.
Old Mar 16, 2011 | 06:57 AM
Henry10's Avatar
Erase it and see if it comes back.
Old Mar 16, 2011 | 08:09 PM
it came back.
Old Mar 16, 2011 | 08:25 PM
Most likely air bag is bad. But double check the wiring behind the glove box insert.
Old Mar 16, 2011 | 08:52 PM
Henry10's Avatar
Check the Purple connector behind the glove department. Just look at it -- do not re-connect or do not do anything with it. If something needs to be done, system must be de-activated first and re-activated later, and there is a procedure to it.
If you don't see any physical problems with the purple connector or wires crushed, the course of action is such:
Dealer has a special equipment for testing. Technician will disconnect the purple connector (i.e. airbag) and plugs the connector into his equipment. Tech will reset the code. If the code does not return, airbag is bad and needs replacing. If the code persists, then Dealer checks the wire from the Purple to the Sensor/computer, by measuring resistance.
Old Mar 17, 2011 | 03:04 AM
Thanks Henry10 & Tech.
One more question, if the driver's seatbelt tensioner needed replacing would that trip the srs light and if so what code would appear?
Old Mar 17, 2011 | 05:04 AM
Henry10's Avatar
Yes. Driver's side tensionser would trigger any of these 4 codes: 231, 232, 233, 234.
There should be a tag on the door with the latest date of SRS service (by dealer). Owner's Manual specifies that airbags, seatbelts with tensionsers should be replaced (by dealer) every 10 years, while wiring should just be inspected. This
Old Mar 18, 2011 | 11:31 AM
Thanks Henry10.
Just an update I had it reset again it is off. I will pray to the Volvo gods for it to be okay since replacement looks to be $1300.
Old Mar 18, 2011 | 12:40 PM
Henry10's Avatar
I bought both air bags, seatbelt units, sensor/computer, clockspring, plus a few other odds and ends (used) for $ 200 at a junkyard. One bag alone might be about $ 50. Putting it in is very straightforward.... Procedures are simple, if you can follow some very simple instructions... Keep that in mind if you wanna pay $ 1300 to yourself...
Old Mar 19, 2011 | 03:33 PM
That will definitely be the way to go if needed.
Great info.
Old Mar 21, 2011 | 10:19 PM
Just for the record it came back on but since I just passed inspection and got a new tag I am not going to worry about it for now.
Old Mar 22, 2011 | 01:00 PM
Henry10's Avatar
I called the dealer today for my V90 Airbag service, and dealer told me that they don't replace them anymore. Just check them for error codes. I did some quick research, and sure enough there is a thread on Turbobricks (SIPS Side Air Bag service??? - Turbobricks Forums) that replacement is no longer necessary, unless that component has failed.
Old Mar 23, 2011 | 08:31 PM
When I was still at the Dealer and the 10 years were up they had us check for codes then install a 15 year sticker.
jmoney2001
Feb 18, 2011 08:16 PM
FujativeOCR
Apr 10, 2010 05:57 PM
Marke
Dec 3, 2009 03:25 PM
Sparky4688
Sep 26, 2009 06:22 AM
guptash
Jan 5, 2005 08:27 AM
