Cold Start - Fuel pressure regulator
Old Dec 27, 2008 | 05:33 AM
Benihana's Avatar
Default Cold Start - Fuel pressure regulator
I'm having cold start issues. It takes a bit longer to start the car than usual in the morning, noticed it starting to happen during the colder days, but it runs fine afterward. I know that there is a strong gas smell in my vacuum line that is connected to the fuel pressure regulator, does that mean its bad? .
Can i use a Fpr from a GMC Syclone? They look exactly the same, and its cheaper by about $20. Does it flow more than our stock one?
Old Dec 27, 2008 | 08:35 AM
bestharry's Avatar
Default RE: Cold Start - Fuel pressure regulator
Try keeping the vaccum line disconnected but endplugged for one night and see if you get normal start next morning.
"I know that there is a strong gas smell in my vacuum line that is connected to the fuel pressure regulator, does that mean its bad?" - might be due to a leak in the regulator resulting in excess gas fed into the engine through vaccum line.
Old Dec 27, 2008 | 11:43 AM
Benihana's Avatar
the only thing is that there is no liquid fuel leak in the line, just the smell is present.
Old Dec 28, 2008 | 09:48 AM
If you smell gas in the vacuum line then it might be bad.
Old Jan 1, 2009 | 02:46 AM
JPN's Avatar
JPN
FYR.
JPN
[IMG]local://upfiles/6892/53F6401F867346F7AB8683D84DD690CE.jpg[/IMG]
MntnDewMan
Apr 3, 2024 04:05 PM
slsnumber1
Mar 15, 2011 02:55 PM
Buck
Dec 28, 2005 01:28 AM
cdunning
Dec 28, 2005 01:27 AM
cdunning
Dec 27, 2005 02:58 AM
