cold weather issue?
Old Oct 19, 2008 | 09:53 PM
litehwk356's Avatar
Default cold weather issue?
so, i bought my 850 at the beginning of summer this year, and havent really had any issues until today.
it was about 28* out when i got into it this morning (way colder than its ever been before when i have driven it)
i got in, started it up, and it immediatly started giving me issues, it did not want to idle right, it kept idling at about 350 rpm's (sounded like it was about to die, but never did) so i let it warm up a bit, and it still didnt get any better. but, i needed to get to work, so i started my 45 minute drive there. the whole way there it felt like i had to give it more gas than usual to get it going, and every time i would let it idle down (clutching, stops, etc...) it would have the extremely low idle issue.by about 15 minutes in, the temp guage was reading normal, but i was still having this issue all of the way in to work, until i shot it off in the parking lot.
went out on break later on when it had warmed up to about 55*, and it ran fine, and it ran fine all the way home as well.
anyone have any ideas on what it could be? im thinking it may be a maf sensor?
it also ate up alot of gas as well while it was doing this.
and i have also noticed it has a bit of a loppy idle
Old Oct 20, 2008 | 12:38 AM
TIPSP's Avatar
Got Boost?
Default RE: cold weather issue?
28 degrees F? that is pretty cold. Sounds like your car needs a block heater if it gets that cold there.
Old Oct 20, 2008 | 08:11 AM
I would make sure the idle motor is clean. Maybe when cold if isn't working properly.
Does the heat work good?
Old Oct 20, 2008 | 08:47 AM
Psaboic's Avatar
Is the check engine light on? I agree with Tech to check the idle motor. It also sounds like it could be the coolant temperature sensor going bad, but I'm not sure if that would only show up in cold weather
Old Oct 22, 2008 | 10:08 PM
litehwk356's Avatar
after it read warm on the heat guage, i got warm air out of the heater.
whats an idle motor?
and 28* is nothing, i live in michigan, it gets to be below 0 here
and no check engine light
Old Oct 23, 2008 | 08:49 AM
The idle motor is a round cylinder looking thing with 2 hoses going to it. It is mounted just infront of the throttle body. Like just under the front part of the black cover over the throttle cable setup.
Old Oct 24, 2008 | 03:52 AM
Maxbaby's Avatar
Tech, what's the procedure for cleaning that idle motor? Or for that matter, for checking it? Just wondering if this should almost be a "preventative maintenance" thing for cold climates?... (Or have I just missed it in my half-hearted attempt at scanning previous posts for a procedure?...)
Old Oct 24, 2008 | 07:17 AM
Alot of places clean it when they clean the throttle body. On the other hand alot of people don't do it at the same time.
To clean it just remove it and clean it with Carb cleaner or Brake cleaner. After it is all clean I always put a few drops of WD-40 or something like that and work it in to make sure everything lubbed.
dieselcruiserhead
Jan 12, 2011 12:27 AM
arttu
Feb 15, 2007 10:16 PM
tpf
Feb 5, 2007 01:31 PM
colgate41
Dec 15, 2005 10:26 PM
smokinjoes
Nov 29, 2004 09:33 PM
