Consensus on turning rear rotors?
Old Nov 12, 2007 | 11:49 AM
robrike's Avatar
Default Consensus on turning rear rotors?
Well, I have my engine back in and drove to work today and all is well other than an annoying vibe in the rear when I applied the brakes. Not sure the condition of the rotors (other than warped) but was wondering what people think about turning the rears? I know turning the fronts is frowned upon but what about the rear? This thing has been laid up for 8 months and I don't remember then being warped when I started the engine pull project but they may have been. Or could having the e brake on for 8 months do that? I would not think so but who knows.
Would you turn them if there is enough meat on them or buy new ones? This is a N/A so no heavy duty driving/racing.
Thanks,
Old Nov 12, 2007 | 12:55 PM
rgs4x's Avatar
Default RE: Consensus on turning rear rotors?
I just did my rear brakes and I think it is just better to replace the rotors. I bought mine at NAPA for $18.99 each. Sure they are made in china but it is just a hunk of metal. The dealer wanted $70 ea. I did use genuine volvo pads though. $72 ouch.
Old Nov 12, 2007 | 01:20 PM
robrike's Avatar
Wow, you don't remember the part number do you? I just called Napa and they want $34.99 each. [:@] It costs $11 just to have one turned so for $18.99 I could not go wrong. Is there a magic word to use to get that price?
Old Nov 12, 2007 | 01:21 PM
jks2's Avatar
Volvo does NOT recommend turning rotors. If they are turned they are almost certain to warp.
Old Nov 12, 2007 | 01:29 PM
robrike's Avatar
I have heard they suggest not turning them. I may just plunk down the money for new ones. More money out the door. [:@]
Old Nov 12, 2007 | 03:16 PM
wheelsup's Avatar
ORIGINAL: rgs4x
You know about FCP Groton right? The 850Volvo pads there are $35. even with shipping($5-$10)you'd still be way ahead. Anyway just a "heads up" for future rear pad replacement!
Old Nov 12, 2007 | 05:10 PM
Systek's Avatar
hey guys, dealers never recommend turning rotors because it is money they dont pocket. any reputable shop will check the thickness and recommend whether it is ok to turn or not. Since they are working on a brake component, they will definitely tell you if turning them is not recommended due to liability issues.dont believe the corporate hype.
Old Nov 12, 2007 | 06:17 PM
I would not turn them they usually make more noise after you cut them and they warp faster.
Old Nov 12, 2007 | 08:04 PM
robrike's Avatar
I want those $18.99 rotors that rgs4x got hold of at Napa.
Old Nov 13, 2007 | 06:47 AM
Quincy56's Avatar
Could be just some rust buildup on the rotors? Maybe just a little light sanding will clean them up?
Old Nov 13, 2007 | 08:44 AM
Psaboic's Avatar
I have heard that leaving the E brake on tightly for an extended period of time can put a slight warp in rotors, but I have never experienced it myself. You can turnthe rotors, but as tech says, turned rotors tend to warp easier. Torquinglug nuts unevenly when changing a tire can warp rotors also.
Old Nov 17, 2007 | 01:05 AM
robrike's Avatar
I think I had a combination of e-brake on for a long time and previous owner letting someone over torque the lug nuts. I had my impact gun rated at 250 ft/lbs and it was having trouble breaking them loose.A few took quite a few hits to even get them started. With that said, I took them to have them miked and they had about 25/1000th left. One would have been fine turned but the other was way warped and iffy. I told him to toss them and purchased new ones.
I have heard that turning takes some "meat" off and thus there is less to disipate heat so they tend to warp easier. It is a fine line as it seems that so little is taken off to turn them but it seems to make a difference, especially on Volvos. There are such good deals on Groton and Ebay that it really is probably better to buy new if possible. I hope to have it back on the ground and ready to run tomorrow afternoon.
adamsrotors
39
Jun 25, 2015 01:01 PM
adamsrotors
49
Jun 25, 2015 12:58 PM
brickrunner
May 6, 2014 12:16 PM
99S70GLT
Aug 3, 2009 12:15 AM
Bruce Wayne
Apr 18, 2009 08:20 AM
