Console Removal - step by step - 94 850
Old Oct 3, 2009 | 12:33 PM
rich nc's Avatar
Default Console Removal - step by step - 94 850
I have to replace or repair the window switch assembly on Sunday (working today) because my driver window is stuck in DOWN position with rain coming in on Monday! I have a new switch assembly (ugh! all 4 plus mirrors @ $141!) in case i need it.
No matter how simple the Haynes manual makes something sound, there is always a glitch so i thought i would see if someone has done this and give me some tips rather than waiting until i get stuck!
As always thanks!
next job, a PNP switch on my 96 960 - whew!
Rich in NC
(any Carolina volvo nuts out there too?)
Old Oct 3, 2009 | 08:17 PM
I have seen instructions on removing it when people have to replace the light in the shifter area. Try searching there.
Old Oct 3, 2009 | 08:20 PM
gilber33's Avatar
I say just go for it. It'll like, be an adventure
Old Oct 3, 2009 | 08:32 PM
Somthngfrce's Avatar
There's a few screws that are hidden under tabs. One is under the e-brake handle. Once that whole section ( where the windows switch) pop up, then it's just a matter of swapping the window switch... Shouldn't take a long time! Good Luck!
Old Oct 3, 2009 | 08:33 PM
mhutchens's Avatar
I have had the center console out of my ’94 850 a couple of times now. Believe it or not it was almost as simple as the Haynes manual suggests.
You will want to disconnect the battery as it suggests because the brains for the airbag system are in the center console and you do disconnect it.
I would defiantly remove the ash tray for “improved access”. It can be a bit tricky to get it out but it will come out.
The only problem I ran into is I gouged out some of the material on the shift handle when lifting out the console. It can be a bit of trick when putting the console back in to get the carpet under it like it was, mine wanted to curl. With the console out it is a great time to get in there with a vacuum and really clean.
You shouldn't have too much trouble following the manual.
Old Oct 3, 2009 | 08:49 PM
gilber33's Avatar
I want a Hayne's manual. Who has one I can has?
Old Oct 3, 2009 | 09:02 PM
I have one I can put on CD....
Old Oct 4, 2009 | 12:45 AM
gilber33's Avatar
OOOOHhhhhhhhh. I would like that. and then and then I can print off necessary pages!
Old Oct 4, 2009 | 07:19 AM
https://volvoforums.com/forum/showth...314#post161314
Old Oct 4, 2009 | 11:11 AM
850tony's Avatar
dude.... i have a window switch i would of sold you for like $40..... let me know if you still would rather go that route
Old Oct 4, 2009 | 12:13 PM
rich nc's Avatar
hey thanks guys.......... i need to get the darn window up. really the prob is the little lens on the driver switch came loose and fell in the switch, jamming it so i cant push in the UP position. i may be able to shake the little lens thingy out of the opening once i get the assembly out (so i can turn it upside down) and just reinstall it. starting on it now!
boxpin
Interior
Sep 17, 2014 11:59 AM
oreng
Dec 21, 2013 04:29 PM
Nicole Lolytte Brown
Dec 4, 2012 10:00 AM
robert213
Mar 16, 2012 12:29 PM
shelbylay
Feb 10, 2009 03:10 PM
