Vibration?
Old Apr 7, 2005 | 02:56 PM
CFGVolvo850's Avatar
Default Vibration?
When idoling in "Drive", the front portion of my 94 850 seems to vibrate somewhat. When in "Park" it seem to supside a little. But when driving, it's not noticeable at all. Could it be that the engine mounts need to be replaced? Car has 103K miles. Thanks again...
Old Apr 7, 2005 | 04:34 PM
Default RE: Vibration?
Thats what it sounds like is the mounts.There is one on the right side of the engine on the bottom.Also check the upper torque mount from the top of the engine.
Old Apr 8, 2005 | 01:26 PM
Is their anyway to tell whether or not they are defective, i.e. cracking, etc? Thanks for your help in this matter.
Old Apr 8, 2005 | 04:20 PM
The one on the right side find the mount on the subframe.Look from the bottom of the mount if the rubber looks really clean and new looking.Then it might be bad what happens is it bounces off the subframe and the rubber looks really clean.Also you can look in the middle of the mount from the side and see if the pin is bottomed out.
The top one try pushing the metal bracket to the side if it is broke the center of the mount will slide out of the outer part.
Old May 15, 2005 | 09:32 PM
djz's Avatar
djz
where can we go to buy these mounts? my 93 is having the same problem
Old May 15, 2005 | 11:37 PM
Search online for Volvo parts.
Me I would buy them from the dealer but not eveyone wants to buy them from there.
Old May 17, 2005 | 05:45 PM
djz's Avatar
djz
im having a heck of a time finding them online, all i can find is performance parts....and honestly....we dont have performance vehicles!!
Old May 17, 2005 | 07:24 PM
knight rider's Avatar
I have been told that if you haven't changed the trans fluid in a while it can cause the transmission to make a bit of noise and have a slight vibration. Just throwing that out there.
Old May 17, 2005 | 11:09 PM
djz's Avatar
djz
i know my motor mounts are trashed, i need to get new ones.
Old May 18, 2005 | 10:59 AM
JimKW's Avatar
Try this link:
https://www.volvoparts.com/index.asp
I bought brake pads from them for a real good price. It's a Volvo dealer.
ocean238
Apr 17, 2008 06:20 PM
JimKW
Jun 14, 2005 06:38 PM
panopticon
Apr 20, 2005 02:11 AM
alecw81
Mar 7, 2005 10:47 PM
Macgregorguy
Dec 19, 2004 03:48 PM
