coolant change
#21
That 50/50 mix cost as much as the 100% anti-freeze. So in essence you get half as much for the same amount of money. When I sprung a leak at Wal-Mart one day, I bought a gallon of the 50/50 to put in my car to get home. I keep that bottle and put my mix in that bottle so I know which bottle is already diluted. As far as distilled water I feel this way: If tap water is good enough for me to drink it's good enough to put in my car.
#22
#24
I don't mix the 50/50 mix in the car. I mix and then put it in the car. Then I save what's left over and use it as necessary. So I have a container with 50/50 mix available to put in the cars. When I'm low I put that in. When that runs out, I mix some more 50/50 and use that to put in the car. That's not rocket science guys.
#25
#26
#27
I just use a coolant hydrometer to see if the coolant is weak or not.
If it is, add more straight antifreeze than water to "strengthen" your coolant. The exact ratio isn't too critical; the coolant hydrometer will tell you what "freeze protection" you have. Just make sure your "freeze protection" (i.e. coolant strength) is at least 10 degrees F lower than the coldest you think it will get in your area.
Of course this all assumes the coolant currently in there has been run for awhile and thoroughly mixed.
no1pony
09-03-2011 06:45 AM
aru5016
06-19-2011 12:26 AM
