coolant leaking
It could be from anywhere:
- Reservoir/its cap.
- Any of the rubber hose connections.
- Water pump.
- Radiator.
- etc...
Can you open the hood and start the engine to idle to see where it's leaking from? Also, how fast are you losing coolant?
To check for leak at the water pump, with the engine OFF, remove the 12mm bolt that is holding the timing belt cover and remove the cover by wiggling it upward; this exposes the timing belt area and the water pump is at the lower-left of that area.
Make sure not to let the coolant level drop until the problem is corrected.
The pics are a courtesy of Bay-13 at Volvospeed.com.
JPN
- Water pump.
- Radiator.
- etc...
JPN
Someone had a post on the procedure here but I cannot find it so here's an alternative:
https://volvoforums.com/forum/general-volvo-chat-5/members-write-ups-7354/
http://volvospeed.com/Repair/timingbelt.php
A Haynes service manual is also helpful. If you have not done this before, work with someone who has done it. Upon completion of the job, make sure to turn the engine by hand (turn the crank pulley with a breaker bar) for at least 3-5 times to make sure that nothing is binding. If the valves & pistons are not in synch, the engine would be damaged when started.
Make sure to use the OEM parts only.
JPN
JPN
