Coolant loss
Old Oct 22, 2006 | 10:22 AM
Volgrrr's Avatar
Default Coolant loss
Recently I had my Volvo garage replace all the hoses on my '95 T5 wagon simply as a general precaution against unexpected failure with summer just around the corner.
Since then I have been frustrated with the vehicle using a substantial amount of coolant.
looking fdor leaks, I think there may be an "O" ring leaking in the heater hose running next to the firewall as green fluid is collecting on the heat shield.
My VADIS indicates there are 3 "O" rings in the heater hoses, presumably 1 is where the leak is - but where are the other 2 "O" rings located?
I've never had anything to do with the clips Volvo use to connect the hoses (they look to be a quick-release type) and wonder whether special tools are needed to remove the clips?
Also, are there any traps for a relative beginner replacing the heater hose "O" rings?
I intend testing the cooling system after the "O" rings have been replaced to make certain the leak(s) have been eliminated.
Does anyone know where I can purchase a pressure test unit that fits directly onto the Volvo coolant reservoir?
Thanks in anticipation.
Old Oct 22, 2006 | 12:58 PM
robert213's Avatar
Default RE: Coolant loss
Part list for Turbo/T5 models
9186849 - Heater Hose Inlet
9186847 - Heater Hose Outlet
3545662 - O-Ring Kit
-- 2 1-ear round white plastic clips (reuse old ones)
-- 2 O-rings
-- 1 white plastic washer
-- 1 black plastic washer
3522035 - 1 Plastic Snap-on coupling
-- 2 2-ear square white plastic clips
-- 2 O-rings
-- 2 white plastic washers
9134878 (Plz verify) - 2 Heater Pipe
3545586 - 2 O-Rings (1 between each Pipe and Heater Core)
9144221 - Heat Exchanger/Heater Core
Old Oct 22, 2006 | 01:01 PM
robert213's Avatar
ORIGINAL: Volgrrr
When the job is done, I intend pressure testing the cooling system to ensure there is no leakage.
Where can I purchase a pressure test kit that fits directly onto the Volvo coolant reservoir?
ORIGINAL: MadeInJapan
In terms of pressure testing the system, I've seen people make-shift a device to the expansion tank of the cooling system by using a tire pump or similar (bicyle pump). It would be fairly easy to get a new green cap for the coolant tank (about $5.00 from fcpgroton.com), drill a hole in it and fit it with a tire valve. Then, all you would do is screw the cap on, pump the expansion tank up with air, and then check with a tire gauge. Let is set for awhile and see if you've lost pressure or hear air escaping somewhere. Not sure how many psi's you're suppose to test with. Others will probably post that information.
I like MadeInJapan's idea of making your own using a regular schrader tire valve and your old coolant tank cap. I guess that it wouldn't hurt anything to put the tire valve on your new one. It would just look strange to be looking at that tire valve everytime that I opened my hood to check something -- like oil level. There is a regular schrader tire valve on the fuel rail, so I guess that the idea is not so strange afterall.
I spent something like $100 for a nice coolant pressure leakdown test kit from NAPA -- and it didn't have proper adapter for Volvo. I proceeded ahead using the leakdown test pump from NAPA. I had to be very careful to prevent the pump from missle-lauching off of the reserve tank. Because of this fear, I checked to see whether cooling system would hold pressure at only 16 psi.
Old Oct 22, 2006 | 11:11 PM
Volgrrr's Avatar
Thanks for the prompt response fellas.
This has given me a few ideas how to go about doing the job.
Much appreciated.
Volgrrr
pforsyth
Oct 25, 2010 09:02 PM
RRTEC
Dec 29, 2009 07:58 PM
lienmarine
Oct 20, 2009 03:49 PM
stojakovic
Oct 11, 2009 08:36 PM
healthnt
Feb 23, 2008 07:08 PM
