Crank-sensor - teeth?
Old Jan 16, 2009 | 04:00 AM
Patriq Backlund's Avatar
Default Crank-sensor - teeth?
1. I'm Megasquirting my -96 855. I'm going over the schematics. It runs Fenix 5.2
It seems there is only a cam sensor - but no crank sensor. Can that be ?
I'm finding a unit called Pulse sensor (7/25) - but I don't think it is a crank sensor.
Does anyone know ?
2. If there is only a cam-sensor. Does anyone know how many teeth/any missing - and where TDC is in relation to missing tooth/teeth ?
3. If there is a crank sensor - same thing: How many teeth/missing - and where is TDC in relation to them ?
Old Jan 16, 2009 | 06:55 AM
JPN's Avatar
JPN
Default RE: Crank-sensor - teeth?
The closest I found is the pulse sensor, as you have described.
Guys, is there a crank position sensor on 850s?
JPN
[IMG]local://upfiles/6892/FD6A08B0396D420DA450B595686E0A71.jpg[/IMG]
[IMG]local://upfiles/6892/0F922B4C14FA4A0CBF2C060407A4BB8D.jpg[/IMG]
Old Jan 16, 2009 | 07:24 AM
Yes that is the Crank sensor JPN.
Not sure on the Teeth part of it. I know there is squares cut into the ridge on the flywheel. There is one section that has nothing. That is how it knows TDC as car as I know. I have never paid attention to where the flywheel when it was set on TDC.
Old Jan 16, 2009 | 09:04 AM
Thanks guys !
So the speedo-sensor and crank sensor is the same !?
Since I'm using it both for ignition and injection timing - I just have to find out about number of teeth and position now.
It is a VR-sensor, right ?
Old Jan 16, 2009 | 09:07 AM
I would see if you can find a used 850 flywheel to look at so you have an understanding of it and what it looks like.
Old Jan 16, 2009 | 09:21 AM
JPN's Avatar
JPN
Great, thanks Tech!
JPN
Old Jan 16, 2009 | 09:34 AM
I'll see what I can dig out.
'Tech' - do you know if the sensor is a VR-sensor or a Hall-type ?
I'd guess VR, but you never know.
Old Jan 16, 2009 | 09:38 AM
I think it is a VR type but not 100% sure.
Gullfisk
Oct 11, 2022 10:18 PM
simonparrish
Jan 24, 2014 08:00 AM
Gullfisk
Feb 16, 2012 04:24 PM
bathtubfartbubble
Sep 4, 2009 12:54 PM
jcmartin
Jun 25, 2005 11:45 AM
