cranks a lot
Old Apr 17, 2013 | 09:42 PM
Yobee's Avatar
Default cranks a lot
What would make my 1997 Volvo 850 crank so much before it starts? It does always start. It seems to me that after it sets awhile is when it happens. If I turn it off, it usally starts on first crank. Thanks
Old Apr 17, 2013 | 09:54 PM
Brick850's Avatar
Have you checked there is fuel pressure at the rail after a long period of rest? It may be dropping and needing to build up again before it starts?
Old Apr 17, 2013 | 10:00 PM
Yobee's Avatar
I just bought the car, I love it so far! And I am new to this forum. I know a little about cars, but what is the rail you are speaking of and do I need a meter to check the pressure?
Old Apr 17, 2013 | 10:05 PM
slimflex2's Avatar
dont worry about it sir. l have a 1997 850R and does the same. nothing to worry about. pressure should be good if you have noo drive problems.
Old Apr 17, 2013 | 10:06 PM
slimflex2's Avatar
l think the 97s were build like that. just saying.
Old Apr 17, 2013 | 10:08 PM
Yobee's Avatar
Thx slimflex2
Old Apr 18, 2013 | 07:22 PM
What do you mean by "takes a while"? How many seconds? Do a video and post it. Have you read the "NEW 850 OWNER THREAD"? It may need a tune up.
If you plan to keep the car longer than a week, you should check the following:
1. Oil change with OEM or MANN oil filter.
2. When was the timing belt last changed?
3. When was the PCV last changed?
4. When was the transmission fluid last changed?
5. Fill'er up and run a bottle of Lucas fuel injector cleaner through the tank.
Welcome to the forum.
Old Apr 21, 2013 | 05:59 PM
Sean Berger's Avatar
^^ what he said ^^ give us an idea of what "takes a while" means. My 850 always cranked a second or two, sometimes 3 seconds longer than a normal car. Its just how they are. Its the 4.3 motronics. I swapped my 97 T5 ecu for a 98 T5 with 4.4, and it was notably different on starting times and idle smoothness. I wouldnt suggest upgrading like that unless you have an obd2 T5 850, Just thought I'd let you know where the issue is, if its only a couple seconds.
Old Apr 22, 2013 | 03:07 PM
matt01's Avatar
ya from my experience it's almost never an ignition problem, and almost always a fuel problem. Either fuel relay, pressure, or something..
nightmarevolvo
Feb 4, 2023 06:20 PM
Luvmateo
Nov 30, 2014 08:22 PM
rainman14624
Sep 20, 2010 09:22 PM
HelgaTheS80
Dec 16, 2006 01:38 AM
steveHut2
Mar 7, 2006 09:18 PM
