Cruise Control
Old Feb 24, 2008 | 06:43 AM
jmkdparks's Avatar
Default Cruise Control
I've got a 96 850 and the cruise is inop. At first the system would lose speed and now I can't even get it to engage. I think it might be a vacuum problem but could be worse. I've got the Chilton's manual but it's useless for trying to find the items and troubleshoot. Can anyone help with their thoughts and a diagram of where the keys parts are (servo, vacuum valve, etc)?
Thanks!
jeff
Old Feb 24, 2008 | 07:19 AM
JimKW's Avatar
Default RE: Cruise Control
A very common problem is the vacuum line right under the battery. I've had it happen to me twice, but it was always fixed in the shop so I'm not sure exactly which hose it is.
Old Feb 24, 2008 | 07:47 AM
JPN's Avatar
JPN
Yes check the simple & obvious first. Visually inspect the vacuum hoses first assuggested by JimKW.
JPN
[IMG]local://upfiles/6892/291D0B2F7D984835A2DE4D241D1F18A1.jpg[/IMG]
[IMG]local://upfiles/6892/B729CA4181104CB19D10520B6D6BA36E.jpg[/IMG]
[IMG]local://upfiles/6892/A6E9FC54436941BF9F88B1F7CE21D105.jpg[/IMG]
[IMG]local://upfiles/6892/B62DA974E9AB4191B322C0697CCE7D0B.jpg[/IMG]
[IMG]local://upfiles/6892/E7E6B15B85D3444996B57F39A66D3C71.jpg[/IMG]
Old Feb 24, 2008 | 10:55 AM
Psaboic's Avatar
Please keep us posted as to how you fix the issue. My son says the cruise on our 95 850 is starting to act a bit wonky. I've never had a problem with it, but.....
Glenn
Old Feb 24, 2008 | 11:25 AM
green850's Avatar
mine also seems to loose speed, if anyone has any experience fixing the problem that would be awesome
not that i really use mine at all.....
Old Feb 24, 2008 | 05:44 PM
98v70's Avatar
For those of you whose cruise control does work. When youclick on the cruise control switch via the signal lever, does a light on the dash come on indicating it's on? I get nothing. I have a 98 v70.
Old Feb 24, 2008 | 06:02 PM
No there is no light.
2000 S40's have a light.
1999 S80 and 2001 and newer cars have one.
russ
Mar 8, 2017 10:10 PM
rspi
Mar 7, 2010 06:13 PM
jfikentscher
May 31, 2006 09:58 PM
Talon
Jun 1, 2005 01:04 AM
CFGVolvo850
May 24, 2005 12:38 AM
