Crumbling shift knob!!!!
Old Jun 15, 2010 | 08:18 AM
audis2vato's Avatar
Exclamation Crumbling shift ****!!!!
The rubber coating on the shift **** of the wagon is either crumbling off or falling off in chunks!! How do you replace the ****? Is their a set screw or does it screw off? I can easily get one at a boneyard but I need to know how it comes off.
Old Jun 15, 2010 | 08:30 AM
boxpin's Avatar
Hah, sorry, all I could think of when I saw this was the Wicked Witch of the West from the Wizard of OZ saying...'I'm Melting!'
Old Jun 15, 2010 | 08:04 PM
fcpgroton's Avatar
Former Sponsor
I know on the S60 you push down and turn. I think on the V70/850 you pull up on it. I would try the push method first.
Old Jan 3, 2012 | 10:07 PM
Cregg's Avatar
Default 850 Automatic Shift **** Removal
Was there any resolution to this? I just bought an 850 and the gear shift **** is rather chewed up.
Also, is there a special procedure for reattaching the cable to the shift **** so that the shifter works properly?
Thanks in advance...
Old Jan 3, 2012 | 10:38 PM
Just pull up on the **** real hard and it will come off. When I put them back on I usually give them a stern thump. Be careful not to damage the shifter button. They crack easy.
Old Jan 4, 2012 | 01:00 AM
Cregg's Avatar
Thanks! I'll head over to PicNPull this weekend and practice on some junky ones before tackling a good one to use.
tupapison
Jul 1, 2006 10:15 AM
jfspring
Jan 29, 2006 12:00 AM
Superfly
Jan 18, 2006 01:15 AM
jcmartin
Sep 20, 2005 08:54 PM
ZIGZAG
Aug 3, 2005 09:56 PM
