dash and climite lights just shut off
Old Oct 1, 2013 | 08:01 AM
bbiljah's Avatar
Question dash and climite lights just shut off
I was just driving last night and BAM no lights on dash or CC o.O the direction lights work, and the 2 little squares for exp: tracs, low wiper fluid, I have those lights on.. but the lights to tach, speedo and such do not work.. fuses under hood are still good.
Old Oct 1, 2013 | 02:12 PM
It sounds like the little dimmer switch might have failed. The lights out you mention are controlled through the dimmer while the ones you say are working are not.
Have you tried moving the switch around a bit to see if the lights come one? They can have dead spots and work in one position and not another.
Attached Thumbnails dash and climite lights just shut off-dimmer-switch-removal.jpg   dash and climite lights just shut off-dimmer-switch.jpg
Old Oct 1, 2013 | 06:37 PM
bbiljah's Avatar
Yea I jiggled it around and moved back and forth, I'm going to put a volt tester on it and see if it's getting power
Old Nov 4, 2014 | 07:20 AM
JimKW's Avatar
I am having this exact same problem. I have tried moving the dimmer switch and I've checked the fuse and it's good. They come on for a while and then go back off and then go on and off asi I drive. Bumps or turning the steering wheel does not make it happen. I tried jiggling the ignition switch and nothing. Sounds like a short somewhere, but where?
Old Nov 4, 2014 | 10:40 AM
Have you tried moving the dimmer when the lights are out to see if that brings them back ??
Old Nov 4, 2014 | 11:29 AM
JimKW's Avatar
Yes. Does nothing.
Old Nov 5, 2014 | 07:03 AM
JimKW's Avatar
How do you get the dimmer switch out?
I googled it and found this on removing the switch:
http://www.atthetipwebs.com/technolo...ash_dimmer.htm
Old Nov 11, 2014 | 03:56 PM
JimKW's Avatar
Bought a new switch from Erie Volvo for $35, put it in in less than 10 minutes and problem fixed.
Old Nov 11, 2014 | 05:01 PM
Life is good
jonqu
Sep 9, 2013 12:31 PM
nitrosport
Mar 12, 2013 06:44 AM
sgplayer69
Apr 17, 2011 12:51 PM
Pyrate
Jun 15, 2009 02:17 PM
colgate41
Sep 14, 2005 11:20 PM
