Dash lights flashing
Old Oct 16, 2007 | 02:03 PM
gutro29's Avatar
Default Dash lights flashing
We have a 1994850 wagon, we recently have had a a weird problem, the dash warning lights(gas light, battery light etc) will randomly flash for no reason. They kind of flicker on and off really fast. It happens at random times and not all the time. Has anyone had this problem or heard of this happening??
THANKS
Old Oct 16, 2007 | 05:40 PM
Default RE: Dash lights flashing
Check all battery connections and grounds.
Old Oct 16, 2007 | 07:11 PM
green850's Avatar
mine did the same thing before my alternator went out
you could always get that checked, just an idea
Old Oct 17, 2007 | 08:35 AM
Psaboic's Avatar
Yep, Check all the grounds and battery connections (clean them as well with a solution of baking soda and water if they are corroded) and see if that helps, if not, as said above, the alternator is most likely going bad.
Glenn
Old Oct 17, 2007 | 10:17 AM
JPN's Avatar
JPN
If the battery connections turn out fine, I would test the alternator with a digital multimeter or have it tested at a reputable shop. If the alternator decides to go, it would be at the worst moment, at the wrong location.
JPN
codeSlinger
Jul 28, 2015 10:21 AM
karsynandjamie
Jul 1, 2015 11:30 PM
Nathan007
Oct 2, 2014 06:32 PM
mep2000
Sep 8, 2009 01:46 PM
javaqen
Nov 25, 2008 04:24 PM
