Dash Lights & power Steering
Old Oct 13, 2013 | 07:53 AM
JohnAndrew's Avatar
Angry Dash Lights & power Steering
Hi
I'm new.
I have a Volvo 850 saloon.
First registered 1993, 110,000 miles.
I parked it for 5 minutes in my driveway this morning.
When I returned, it started ok
However, virtually all of the dashboard warning lights stayed on.
Also, the power steering seems to have failed completely so that the vehicle is virtually impossible to drive.
Any suggestions?
JohnAndrew
Old Oct 13, 2013 | 08:12 AM
Brick850's Avatar
First of all, welcome!
I would say your drive belt has broken or dislodged. That would stop the alternator charging, which makes all your lights come on, and makes the power steering pump stop working.
Have a look on the left side of the engine, there should be a long belt visible that loops around the power steering pump, a/c compressor and alternator as well as the engine pulleys
Old Oct 13, 2013 | 09:57 AM
Hi and welcome.
If the serpentine belt broke you will need a special tool to get it back on. Some people go to a hardware store and get a 3/4" gas line plug and use a pipe wrench to turn it.
After you get that sorted out, you might want to watch a few video's and read a few sticky's to get up to speed real quick on how to care for your new found 850.
Old Oct 13, 2013 | 03:18 PM
JohnAndrew's Avatar
Default Drive Belt
H1 Brick
Thanks for responding.
How do you explain the fact that the engine starts and the cars moves forwards and backwards [enough for me to park in the garage]?
The last time the drive belt broke, it screwed up all the valves and I certainly was not able to restart the engine.
JohnAndrew
Old Oct 13, 2013 | 03:37 PM
JohnAndrew's Avatar
Default Drive Belt
Hi Brick [again]
I guess I'm confusing the drive belt and timing belt.
I have checked the car and there is a broken belt [ca 3 cm across and ribbed]
Thanks again for your prompt and knowledgable response.
Best wishes
JohnAndrew
Old Oct 13, 2013 | 07:20 PM
Serpentine belt. Out of cover.
Timing belt. Under cover.
Old Oct 13, 2013 | 07:22 PM
Originally Posted by JohnAndrew
The last time the drive belt broke, it screwed up all the valves and I certainly was not able to restart the engine. JohnAndrew
Yes , a Volvo certainly will.
Always a good idea to check out advise before dismissing it
Old Oct 13, 2013 | 08:53 PM
Brick850's Avatar
Thanks rspi - I was wracking my brain last night and I could not think of the word serpentine.
A major brain fart was had by me.........
Josh913
1998-2000 model year XC70
Oct 20, 2014 07:46 PM
volvolady610
Jan 1, 2013 06:19 AM
whiteboy
Apr 26, 2010 02:37 PM
850GLE
Sep 22, 2009 10:28 AM
huzzsaba
Apr 2, 2009 05:35 PM
