dash switch lights
Old Dec 27, 2012 | 08:09 AM
Lizella Fella's Avatar
Default dash switch lights
Which of the dash switched should be illuminated when the head lights are on? Presently, the hazard light switch is on. Should all the others be as well?
TIA
LF
Old Dec 27, 2012 | 11:16 AM
All except for the dimmer.
http://atthetipwebs.com/technologyin...itch_bulbs.htm
Old Dec 27, 2012 | 01:39 PM
Great! Thanks, I have some bulb swaps to do. BTW, I have a Draper "expert" Service Indicator Rest tool, P/N OSR/VOLVO that came with my donor sedan. However, I cannot find an instruction sheet in the paperwork that came with the car, nor doing a google search, can I find one.
Several post indicate that this tool will turn off both the engine service interval light as well as the SRS light. However, just plugging the unit in does nothing. Just a green light on the front.
Any help would be greatly appreciated.
Old Jan 2, 2013 | 08:11 AM
Got all the switches working so that worked out well. Found the bulbs at radio shack. While doing this job I wondered if anyone here, with a 850 base model, has utlized the rear fog lamp switch to power front fog lamps?
Also, What do the fog lamps for a 1997 850 look like. My car is equipped with the wiring behind the front bumper for the lights, but none were installed at the factory. In addition, the openings on the bumper have small plastic grills installed. The right side also has a tow loop.
tia
lf
Old Jan 2, 2013 | 04:19 PM
Like this ??
95 97 Volvo 850 T5R L R Fog Lights 850R Plantinum Edition Foglights Kit | eBay
Attached Thumbnails dash switch lights-96-97-volvo-fog-lamps.jpg   dash switch lights-fog-light-housing.jpg   dash switch lights-fog-lights-installed.jpg
Old Jan 2, 2013 | 08:38 PM
Yes I have used the rear fog. They all have the feature, it's a Volvo safety thing. It only lights up one bright bulb on the drivers side, by design. So it doesn't get confused for a brake light.
Old Jan 3, 2013 | 07:06 AM
Rickford's Avatar
Without getting on my back and fishing around for a possible connector (I'm not young...I'm old would there be pre-wiring for fog lights on a 94 850 NA Base mod if anybody knows? Thanks in advance!
Rickford
Old Jan 3, 2013 | 08:09 AM
Thanks for the pictures. Based on this, I'll need to cut holes in the front lower bumper cover to install the lights. I think I will pass on that. Maybe I'll install some small LED strips in the lower grill/vents like some of the new mercedes models. thoughts?
TIA
LF
Old Jan 3, 2013 | 01:17 PM
Rickford
Depends on how "old" you feel. You don't need to get on your back but you do need to get on your knees. If you pop the plug out of the dash you should be able to see if there is a connector there. If that connector is behind the blank in the dash then you might want to make sure you're wired under the bumper by sliding under. You don't need to use a creeper, cardboard keeps you clean and also gives you more clearance.
Attached Thumbnails dash switch lights-fog-light-switch-dash.jpg   dash switch lights-fog-light-connector-under-front.jpg
Ratphink120
Mar 11, 2022 10:41 AM
ParkCity850
Nov 28, 2012 02:12 PM
mikwik
Oct 22, 2011 05:42 PM
850GLE
Sep 22, 2009 10:28 AM
KGads
Feb 29, 2008 07:11 AM
