dead cyl. can I unplug fuel injector?
Old Dec 28, 2010 | 07:36 AM
grigalid's Avatar
Default dead cyl. can I unplug fuel injector?
I did a compression test on my car a while back and discovered that the last, or first, cylinder is completely toast. I did not bother with a leak down or anything because I am looking for a used motor to swap it with.
Can I disconnect to fuel injector from that cylinder as it has 0 psi. This will prevent me from contaminating my oil so much and wasting fuel.
Thanks for the help.
Old Dec 28, 2010 | 01:37 PM
I guess you can try it but I think that would throw a cel and may cause other problems as well. If you are driving around with a bad cylinder, I guess none of it matters because you are driving around with a ticking time bomb.
blk07dub
Aug 21, 2013 07:41 PM
boothguy
Jul 23, 2012 09:33 AM
scrantonauto
Dec 19, 2010 07:20 PM
ozmanyyy
Jul 20, 2010 07:30 AM
