Directional issues
Old Aug 26, 2011 | 08:50 PM
olesy1064's Avatar
Default Directional issues
Hi. I just bought a 1994 volvo 850 with 160k miles on it. I love it. But I am having a big issues. In New Hampshire we need to pass inspection. I can't because of my passanger side directional is not working. Here is what I did..
I replaced the front passanger directional bulb because it did not turn on when the lights where on. Now my drive side works fine. My passanger side when turned on without the headlights being on, blinks all of my directional lights on both sides and my rear running lights and my rear plate lights.
With my headlights on and I turn on my passanger directional, it turns on and stays on without blinking.
Is this a grounding issue or a relay issue or is it something else?
Help... Thanks
Steve
Old Aug 26, 2011 | 09:05 PM
My guess would be that you have a bad light switch. 960's Have problems like that but it's usually a bad bulb. Make sure all of the bulbs are correct and that none of them have the dual tips smashed together.
Old Aug 26, 2011 | 09:21 PM
olesy1064's Avatar
Would this be the head light switch or the directional switch?
I will check the light bulbs in the morning. Is there anything else I could check before I start changing switched?
Old Aug 26, 2011 | 10:06 PM
Head light switch.
Old Aug 27, 2011 | 07:56 AM
olesy1064's Avatar
I should also add that my passanger side directional light is stuck on when I turn my headlights on. Do you still think this is the headlight switch?
Thanks
Old Aug 27, 2011 | 09:01 AM
olesy1064's Avatar
Ok, I checked the light bulbs and they only have one contact not the two that are in the picture above. If I turn on the headlights without the front passanger directional light in is the rear passanger directional bulb only, no other lghts blink and the dash light turns off. I am not convinced that the headlight switch is it? Any other thoughts?
Thanks
Old Aug 27, 2011 | 09:25 AM
A bulb somewhere or a shorted wire. Again, make sure you have the proper bulbs installed in all locations. Not sure if it's the same with the 850, but the 960 uses the hazard switch as a relay. The switch is about 6 inches long.
Old Aug 27, 2011 | 02:32 PM
olesy1064's Avatar
Thank you for your help it was a bulb. the brand new one I put in was correct for that model year but my car was made at the middle cycle cross over to 1995. Now with the correct bulb everything is good.
Steve
Old Aug 31, 2011 | 07:09 PM
Chris 850T's Avatar
I have a similar problem with my 96 850. The passenger turn signal/driving light only comes on when using the signal. It wont turn on with the headlights or blink when I lock the car/arm the alarm...not sure why. I haven't pulled the bulbs yet though.
Aferthas
May 13, 2010 07:01 PM
sccadsr31
Nov 6, 2009 11:14 PM
SkottinNJ
Sep 20, 2006 10:59 AM
etype38
Feb 1, 2006 06:26 AM
willko1
Jan 20, 2006 09:08 PM
