HELP directional pattern, side specific rotors??
Old Jan 20, 2006 | 12:02 AM
willko1's Avatar
Default HELP directional pattern, side specific rotors??
Just got some rotors in the mail cross drilled Zimmerman’s (spiral pattern) part# 271788zd for a 1999 v70 2wd. Well they look great but I noticed that the direction or pattern of the holes will be spinning one way on the driver front and the other way on the passenger front. I feel like this may affect the way the pads grab or are the cross-drilled holes just for heat dissipation.
Are these rotors SIDE SPECIFIC?
It seemed odd to me and out of sink visually as well as mechanically.
If I am completely off my nut about that and it is OK is there anything I should do to prep these before install i.e. do they rust quick on the inside hub? Thanks
Old Jan 20, 2006 | 09:08 PM
Default RE: HELP directional pattern, side specific rotors??
Do they both have the same Part #'s?
Did you call the company you bought them from?
Aferthas
May 13, 2010 07:01 PM
sccadsr31
Nov 6, 2009 11:14 PM
SkottinNJ
Sep 20, 2006 10:59 AM
etype38
Feb 1, 2006 06:26 AM
