Dome light
Old Jun 27, 2007 | 08:45 AM
xjflexer's Avatar
Default Dome light
In my '96 850R, the dome light in front of the sunroof does not come on when I open any of the doors. I have it set propperly for it to come on with the door, but it doesn't work. The RED lights on the doors themselves do come on with the door open. The overhead light DOES work when I turn it on manually, so I know the assembly works. Is there a master relay for this light?
Old Jun 27, 2007 | 05:33 PM
Default RE: Dome light
The switch part for the doors in the dome light assembly might be bad. (contacts)
Old Jun 28, 2007 | 08:47 AM
axelm's Avatar
I've disassembled that part and the quality of the components is horrible. Probably the contacts are bad.
Old Jul 2, 2007 | 06:58 AM
xjflexer's Avatar
Thanks for the replies. Tech, I just want to make sure I understood. The switch contacts for which you speak are located INSIDE the dome light assembly? If so, that should be easy enough to fix.
Old Jul 2, 2007 | 05:45 PM
You can try most of the time you can't gain access.
Or something is broke that takes way to much time to repair.
s80kid
Jan 22, 2011 11:12 AM
a4ty4d
Sep 9, 2010 08:56 PM
manuel
Jan 14, 2009 05:42 AM
ikey
Dec 15, 2008 06:05 PM
volvobacon
Sep 30, 2005 09:25 PM
