virbation while braking
Old Jul 4, 2007 | 08:33 PM
glt93's Avatar
Default virbation while braking
When i brake at speeds over 50 my car shake and just last week as i was acclerate it does the same as if i was braking
Old Jul 5, 2007 | 01:36 AM
RedTurbo850's Avatar
Default RE: virbation while braking
Warped rotors probably.
Old Jul 5, 2007 | 02:43 AM
JPN's Avatar
JPN
Default RE: vibration while braking
Or, it could also be one of the following:
1. Uneven pads wear-related to warped rotors(in case if the rotors are warped or the pads have worn unevenly, replace both components).
2. Loose suspension components/hardware.
3. Worn/cheap tyres or alignment out-of-spec. Visually check the tyres to see if you can find something unusual (uneven tread wear, missing treads, etc...). Ensure tyre pressures are within the specified range.
Let us know if you need further assistance. With the info you've provided, this is the best I can do for now.
JPN
conceptmuscle
Dec 28, 2007 01:40 PM
xxjoeyxxeb
Oct 21, 2007 05:16 PM
Red XC
Oct 24, 2005 02:51 AM
fixavolvo
Jan 28, 2004 05:24 PM
