door check
Old Apr 14, 2013 | 11:26 PM
Phil 850's Avatar
Default door check
Looks like my drivers door door check is shot. What do I need to do to change this? How much of a project is it?
Old Apr 15, 2013 | 04:03 AM
I've seen a few post about it, most involve welding the crack in the door.
Old Apr 15, 2013 | 09:23 PM
goldponcho's Avatar
More detail? Is the door check itself broken, or the door metal fatigued and cracked? The check itself was broken on my sedan when I bought it, and replacement is easy enough once the door panel is removed. My wagon, on the other hand, had a long crack forming along the door that required welding.
Old Apr 15, 2013 | 11:50 PM
Phil 850's Avatar
I'll look at it tomorrow but it acts like the check it self is the problem because when you open the door it swings all the way out with out stopping.
Old Apr 17, 2013 | 11:49 PM
Phil 850's Avatar
I got a chance to look at it and don't find any cracks so I'm still going for the door check.
Old Apr 18, 2013 | 08:09 PM
goldponcho's Avatar
Door check is easy enough to replace, if you can handle getting the door panel off. I believe the Torx bit is a 35 or 40 to disconnect it from the door jamb. A couple of 10mm nuts or bolts to remove from door. A little wrestling to get it out, and reverse steps with new replacement. Fronts are same left/right.
jpirish
Dec 5, 2010 11:12 PM
donf
May 26, 2010 09:40 PM
MC92
Apr 19, 2009 09:11 AM
yellow95
Sep 19, 2008 06:31 PM
yellow95
May 1, 2006 08:59 PM
