Dumbest question of the day
I went to check the tranny fluid today and I can't seem to get the dipstick out!!! Does it screw in? Is there some sort of trick?? I pull on it and it just won't budge.
This is the first time I've tried to check it since I bought it 4 months ago.
Any ideas??
Any ideas??
Keep tapping it lightly with a plastic/rubber mallet and when pulling on it give it a twist. Also, see if you cansoak the area with clean Dexron-III/Mercon and let it soak in for a half hour or so.
JPN
JPN
As everyone has said. It should just pull out. Once you get it out, I would plan on getting a new seal/O-ring for the dipstick. If it has hardened enough to stick, it will probably tear or stretch when you pull it out.
Glenn
Glenn
Finally got it. Sprayed a little WD-40 on it, let it sit for 15 minutes and then it broke loose.
More good news. The tranny level looked and smelled good.
Thanks for your help guys
fcpgroton
Feb 15, 2010 10:36 AM
