easiest point to hook a boost guage?
Old Oct 17, 2006 | 03:27 AM
dannydoo's Avatar
Default easiest point to hook a boost guage?
Where is the closest?
where is the easiest?
or the best
location or route...to hook up A boost guage?
Ive had it!!!!!!! I wannna know EXACTLY WHATS GOING ON.
also.........a route for an oil guage i need too.
Old Oct 17, 2006 | 09:27 AM
MikeySq's Avatar
Default RE: easiest point to hook a boost guage?
you can use a new line all the wat to the lil vacuum tree on the intake and rout it that way or there are oodles of other spots you can 'tee' in to
3/16 ID fuel line fits great over the line for the factory boost gauge line right up front by the battery you could use some of that to splice in to it
-Mike
Old Oct 17, 2006 | 02:21 PM
code33's Avatar
What Mikey said...
To penetrate the firewall, there is a short conduit above the driver's side footrest. It's capped off at each side; look for a rubber cap with three nipples on each side.
Old Oct 17, 2006 | 03:54 PM
dannydoo's Avatar
thanks guys
thats what i wanted to know.
but was hoping maybe there was a vacume line right on the dash somewhere.
is there an oil sender anywhere? i can hood the oil guage to? the one i have is not electric
Old Oct 17, 2006 | 09:07 PM
Why noy use the line at the Dash if you look under the dash you can't miss it.(from the stock guage)
The oil sender location is in the pic.
[IMG]local://upfiles/853/6AC10B71419D477FA6CBBC87D689113D.jpg[/IMG]
slimflex2
Jun 13, 2013 11:36 PM
VTBricked
Aug 20, 2011 05:45 PM
BlazeS70
Jul 3, 2009 03:15 PM
dlehnhoff
Apr 28, 2007 06:42 PM
Boosted_s80
Nov 8, 2005 09:02 PM
