ECU swap (replacement)
Old Jul 28, 2010 | 03:22 PM
pww571's Avatar
Default ECU swap (replacement)
Hi! My 1996 850 (2.4 5cyl. 20v 5 speen manual NON-turbo) quit working, and we've traced it back to either the coil, or the ECU. and i was wondering if i could swap the ECU with a different ECU that i already have as a spare (from a '97 850 - presumed to be a 2.4 5 cyl 20v AUTOMATIC non-turbo) My question is; does the replacement ECU need to be flashed or programmed to my current car to work? or is it just interchangable? I dont want to put it in and damage the car through the anti-theft or by some other means in the electriacl system. and feedback would help. thanks a bunch!
-Cheers!
Old Jul 28, 2010 | 03:36 PM
gilber33's Avatar
You'll get a CEL and flashing arrow for the missing TCU since you have a manual.
Old Jul 28, 2010 | 03:48 PM
pww571's Avatar
should i just try to get one programmed for a manual then? thanks for the reply!
Old Jul 28, 2010 | 03:55 PM
gilber33's Avatar
I guess if you want to spend the money and if it's going to be permanent. Or just find a used one. Are you even 100% it's the computer?
Alan Eliass
Oct 29, 2013 09:04 AM
makaveli2k
Aug 8, 2012 12:32 PM
matt01
Jul 23, 2012 11:12 AM
91shelby
Jun 20, 2011 06:56 PM
bigern45
Aug 5, 2008 08:14 AM
