Emergency brake not working
Hi everyone. The emergency brake on my 96 850 has not worked for a few months now. I thought it was the rear shoes but I recently completely replaced my rear brakes. I tightened the screw in the center console and that seems fine. Im not sure if maybe we missed a step when doing the rear brakes? Or if there is another issue?
Any advice or suggestions would be really appreciated. Thank you!
I would replace the cable and the pads. I believe fcp sells Bosch for under $40. I read somewhere on the forum that pads are a lifetime part since it doesn't get used all of that often. While that maybe true, they will "dry out" from the age. I just replaced mine and they fell off as soon as I took the rotor off. The actual pad felt like old plastic that I could easily break with my hands, see picture below. My ebrake still doesn't work after replacing the pads so I'm assuming that the cable is seized, most of these cars are around 20 years old now so it's to be expected
Agree that you should do both the shoes and the cables to the wheels. After installing the new pads you will need to adjust the emergency brake shoes at each wheel. there's a slot with a rolling adjuster - use a screw driver to adjust until the pads put drag on the wheel. Then you can adjust at the hand brake lever to get the slack out of the cables - should take about 4-6 clicks to set the brake.
I replaced my rear brakes and emergency pads at the same time and was barely able to fit the rotor over the pads even with the adjustment all the way down. Sometimes they squeak especially after I leave the city with a lot of potholes (DC)I'm still getting no resistance from the emergency brake lever. How many cables are there? Is it just one or is there a splitter?
