Emergency Brake Cable
Old Mar 16, 2006 | 09:01 PM
rmmagow's Avatar
Default Emergency Brake Cable
1998 V70 AWD.
How difficult is it to install an entire new e-brake cable set-up in this car. My handle moves but no brake action. I'll be checking the connections later this weekend but am asking this question in anticipation of having to re-build the setup.
Thanks Much
Old Mar 17, 2006 | 09:02 PM
Default RE: Emergency Brake Cable
First check the adjustment under the center console. lift up the arm rest lid.Then remove the cover in the bottom of the hole. You should see the adjustment screw.
If nothing after adjustment then remove the rear rotos and check the E-brake shoes.
Old Jul 8, 2006 | 12:45 AM
98v70's Avatar
I've searched and found this thread regarding emergency/parking brakes. So I'm bringing this back up!!
Does the e-brake lever have to be down or up before I adjust the screw inside the center console? Will the screw be obvious? I hope adjusting screw will work. Not prepared to mess with the shoes in the rear.
Old Jul 8, 2006 | 12:49 AM
Handle down.
Once you remove the cover in the bottom of the Console the screw will be in the front of the hole.
Old Jul 8, 2006 | 01:04 AM
98v70's Avatar
Thanks Tech. So the whole center console needs to be removed correct?
Old Jul 8, 2006 | 01:20 AM
No just the little cover in the bottom of the Cubby at the back of the console. Lift the lid and look on the bottom you will see a little cover that comes out.
Old Jul 8, 2006 | 01:44 AM
98v70's Avatar
So this is close to where my obdII port is? inside the armrest? Just so we are on the same page...I have a 98 v70.
Old Jul 8, 2006 | 01:45 AM
Yes in the bottom of that cubby.
Old Jul 8, 2006 | 01:48 AM
98v70's Avatar
Thank you so much Tech. Sorry for any frustrations I may have caused. I'm at work now and don't have my manual to look at. I'm getting to it tonight.
Old Jul 8, 2006 | 01:51 AM
No problem.
One day I will take pictures and make walk throughs.
Old Jul 8, 2006 | 01:56 AM
98v70's Avatar
Wow. That would really be appreciated. Can I suggest a walk through of all things related to changing rear shoes? (just in case adjusting only won't work)
Old Jul 8, 2006 | 10:35 AM
Suggestion got but I will most likely be a while before I end up doing one.
It is not very common to have to do it. But if I do one I will make a walk through.
Old Jul 8, 2006 | 06:25 PM
98v70's Avatar
ok I tightened (clockwise) the screw. The car dosen't seem to roll as much after parked. But it still feels as though the brake lever goes up quite a bit, maybe 10-11 clicks. Normal?
Old Jul 9, 2006 | 01:01 AM
I usually try to keep it around 6 clicks.
BTW here is what the Handle and Adjuster looks like.(But with console out)
[IMG]local://upfiles/853/A00667B2823245C0AB4E8D9A76674705.jpg[/IMG]
Old Sep 16, 2006 | 06:05 PM
flyer1's Avatar
have done this today , as allso failed mot on reverse travell , removed rear hubs and cleaned shoes rewound self adjusters , and cleaned all , think i might need new cable as when cables pulled with hand brakes release , wheels turn freely seems to work fine when car on ground but wheels lock when car lifted.
jonathan1280
May 10, 2019 01:44 PM
arthur240
Feb 7, 2011 09:35 AM
rmmagow
Jun 8, 2006 08:44 PM
arthur240
Jan 28, 2006 04:52 PM
jcmartin
Aug 1, 2005 06:18 PM
