Emission Control system leak
Old Nov 28, 2008 | 03:50 PM
crotext's Avatar
Default Emission Control system leak
'97 850 GLT -
Engine light is on. No effect on the cars operation that is noticeable.
I ran the codes and got "PO442 - Emission Control System Leak detected
(small leak)"
I am not at this point totally familiar with the system but I looked for bad
vacumn hoses, connectionsetc and found nothing that would be obvious.
Hasanyone had this problem and/or have any suggestions on where to start
tracking it down? Since the car is still running fine, is it something that can
wait until we do the total PCV clean up later on?
Any help is appreciated. thanks!
Old Nov 28, 2008 | 04:08 PM
Default RE: Emission Control system leak
That is a different system then the vent box system.
The best bet would be to have it smoke tested or make a tool like I did and add pressure to the system.
I posted pics and made a post a pinned topic."Home made special tool"
If yo decide to do that let me know so I can give you more info on doing it.
Old Nov 28, 2008 | 04:30 PM
crotext's Avatar
Hello:
Thanks for the quick reply. I am to new to the Volvo systems
to get much from it however. I am planing on giving this car
to a boy I am raising for his birthday next summer. So I am trying
to teach him all I can about it as i go. He doesn't know it is going
to be his but I am buying all the books and code readers that
apply so he can work on it.
Before we get too mechanical or technicalon this: have you ever heard
of anyone having this happen after running "regular gas?"On my way
back from Los Angeles to MT, I ran into a very busy gas stop and after
using my card, the premiumwas not working so I filled with regualr. I am
not sure it was such bad gas because the car still ran smooth. But, could
the sensors have been affected some way? If so and I cance the light, it
should stay off right?
Guessing and hoping for a cheap fix. He, he!
Old Nov 28, 2008 | 04:37 PM
NO that will have no affect on those codes.
For the tool I made it is a regulator and a guage and a couple of airline fittings.
If you have access to a compressor then you can search for the leak.
You might also have a bad evap valve on the cooling fan. Worse case is the fuel pump housing is cracked causing the leak.
Old Nov 28, 2008 | 06:24 PM
JPN's Avatar
JPN
And make sure to introduce this forum to the boy.
My 1st & 2nd replies in the following thread may help some...
https://volvoforums.com/m_48928/tm.htm
JPN
robingichuhi
Feb 22, 2017 04:34 PM
S80guy
Aug 18, 2014 07:18 PM
tcarp104
Jan 4, 2005 11:48 AM
tkruid
Nov 17, 2004 10:45 PM
