engine lifting points
Old Mar 26, 2006 | 12:29 PM
JohnM's Avatar
Default engine lifting points
OK so I have been thru my after market shop manual and looked all over the web. Can someone direct me to a photo or diagram of the lifting points on a 95, 2.4 vj series engine. I am changing out the oil pan and need to lift the front. As I understnd it 30 mm is as far as I dare lift so as to not bind the trans axel connections.
Old Mar 26, 2006 | 01:43 PM
Default RE: engine lifting points
I have not had to lift the engine to remove the oil pan on the 850.
If you really wanted to you would have to make a craddle that went from inside the fenders on each.
From one fender to the other then make something to lift the engine.
jbjlock26
May 3, 2015 07:32 PM
850v
Mar 7, 2013 10:00 AM
speedracer67
Jul 24, 2010 12:12 PM
Dan_68c
Mar 15, 2010 07:31 AM
chadpb2626
Sep 3, 2005 06:33 PM
