Engine misses in first few minutes
Old Jul 11, 2011 | 02:26 PM
greg 850T's Avatar
Default Engine misses in first few minutes
I've owned my 96 850T since 02 and it's developed a new problem. When I first drive the car, it feels like one cylinder is not working for the first 2 min or so. The care runs very roughly and shakes - also low power. After about 2 min, it starts running on all 5 cylinders and never returns to rough running. Note that it is about 95F out here, so I'm not sure that I would call this a cold-start problem.
Plugs, wires, dist cap are now new.
Thanks
Greg
Old Jul 11, 2011 | 03:53 PM
I'd suggest you do a compression test. There is a chance you have a vacuum leak but you may have a sticky valve or something.
Better yet, you should check your fuel injectors. Have you run any injector cleaner in the tank lately? I usually run Lucas fuel treatment in the tank every 10,000. They suggest every 2,000 but I alway run band name fuel and 93 octane.
Old Jul 11, 2011 | 04:28 PM
greg 850T's Avatar
Thanks for the suggestions.
If the injectors have some clogging, would they clear up when they get a little hotter?
Also, it is possible that I have some crud/carbon on my valves as I rarely drive more than 30 min.
Do you have a suggested product for dissolving carbon - other than removing the head and scraping, or blasting with walnut shells, etc.
Thanks again
Greg
Old Jul 11, 2011 | 07:04 PM
Typhoon's Avatar
It's not injectors. Injectors wouldn't magically self clean every start. Even a leaking injector will clear the cylinder in 10-15 seconds tops.
Most likely causes are a stuck valve (unlikely if it clears) , a fouling plug or compression loss/coolant leak.
Old Jul 12, 2011 | 12:30 AM
gdog's Avatar
In addition to cold compression test also ck the fuel pressure when cold...
Old Jul 12, 2011 | 07:56 AM
Greg, I would start with the injector cleaner. The bottle claims that it cleans sticy gummed up valves as well. As for driving over 30 minutes, a lot of people don't. The hard thing on a motor is the first few miles. My wife use to drive her jeep 6 miles to work and 6 miles back. Took 4 miles to properly warm the thing up. As long as you're driving past the 5 minute mark the car is at temp and should be fine.
John Ross
Sep 20, 2020 04:04 AM
j1911e
Sep 9, 2010 04:51 AM
ederm
Jul 7, 2010 08:29 AM
MaxIcon
Apr 13, 2010 02:21 PM
azhjph
Sep 8, 2009 10:27 PM
