Failed Smog: P0455evap Central Systems Gross Leak Detected
Old Apr 29, 2011 | 10:51 AM
boxpin's Avatar
Default Failed Smog: P0455evap Central Systems Gross Leak Detected
A friend text me asking about a failed smog. I am assuming from the message that there is a leak in the evap system somewhere. From what I understand this is the cylinder that is under the drivers front fender and connects to the intake manifold and the fuel tank. Common fail area is right past the fuel filter under the passenger rear wheel. Not saying thats what the problem is or where(havent looked yet).....any other ideas?
96 850
Old Apr 30, 2011 | 10:29 AM
Henry10's Avatar
That means that vapor flow is blocked. I would check the Purge solenoid, vacuum connections, and electrical connectors.
MissKristenMarie
Dec 12, 2009 12:33 PM
dwill130
Jan 8, 2009 09:27 AM
tassadar30
Apr 23, 2007 11:07 AM
tassadar30
Jun 22, 2004 01:16 AM
