Fan Speed Selector?
Old Apr 23, 2013 | 01:18 PM
NOVALOU's Avatar
Default Fan Speed Selector?
The fan only comes on when the selector is set to the highest setting. Itdoesn't matter if I’m using the heater or A/C.
Can you guys give me some suggestions on were the problem may lie.
Also, is the selector switch easy to get to?
Thanks in advance,
Old Apr 23, 2013 | 06:05 PM
If you've checked the fuses then the next item would be the blower motor resistor.
Do you have a manual (MCC) or automatic (ECC) system
Old Apr 24, 2013 | 01:41 PM
NOVALOU's Avatar
Thanks for the response.
How do I tell the two systems apart?
Old Apr 24, 2013 | 02:02 PM
If you have the owners manual it will show you the difference.
The automatic has a slider with variable speed control the manual system has set speeds, one through four I think.
Attached Thumbnails Fan Speed Selector?-heat-ac-ecc-panel.jpg   Fan Speed Selector?-heat-ac-mcc-panel.jpg
Old Apr 24, 2013 | 04:23 PM
NOVALOU's Avatar
Mine is the same as the one on the right, so that would make it a manual?
Old Apr 24, 2013 | 04:54 PM
You have an MCC. It makes a difference when you go to pull or purchase a blower motor resistor.
I'm not saying it has to be the resistor it's just the most likely thing to try.
Old Apr 24, 2013 | 05:04 PM
1995Volvo850's Avatar
I have exactly the same problem with my manual climate control.
Is there a way to fix my apparently broken resistor?
Old Apr 25, 2013 | 04:41 AM
No, just replace it.
Old Jan 18, 2014 | 05:25 PM
NOVALOU's Avatar
Changed the resistor and it's working fine.
Old Jan 18, 2014 | 06:46 PM
bassettsnose
Jan 4, 2011 03:26 PM
volv04
Jan 6, 2009 05:05 PM
paulbelanger
Aug 9, 2006 10:13 PM
charlesbattaglia
Dec 8, 2005 11:56 PM
parrym
Nov 7, 2004 11:30 AM
