Faulty temp gauge
Old Aug 13, 2009 | 12:26 AM
jnduke's Avatar
Default Faulty temp gauge
My temp stays down (like 0) until the engine is nice and warm- 10-15 minutes of driving, and then it comes up to the appropriate range. I'm thinking that the sending unit is going bad and is having increased resistance in the circut that it can't overcome at low temps, but once it has hit a certain voltage then the circut completes and put out the signal.
Anyway- not an electrical engineer- but wanted to know if anyone else had experinced this issue. Car is a 850t 1996, with 140K. I'm thinking of just starting with a new temp sensor, and new thermostat, and thinking that will fix it.
Thanks
Old Aug 13, 2009 | 02:30 AM
850tony's Avatar
i would go that route also
Old Aug 13, 2009 | 09:07 AM
fcpgroton's Avatar
Former Sponsor
+1, It is not expensive to swap them out and it could be all you need.
Old Aug 14, 2009 | 08:07 AM
Psaboic's Avatar
Sounds like a plan. FWIW, the Torx screws that hold the thermostat cover on are a real PITA at times. I would replace them with regular hex head's while you are in there
Old Aug 14, 2009 | 09:21 AM
fcpgroton's Avatar
Former Sponsor
+1, also soak them in PBlaster overnight or you will strip out the threads.
Old Aug 14, 2009 | 03:32 PM
silkhope's Avatar
Extended torx socket will make it easier.
Old Oct 29, 2009 | 09:54 PM
jnduke's Avatar
Silk hope you are right. Those TORX are beast. Just to follow up the condition-
I replaced thermostat and sensor- so it's a chicken and egg thing...
Now I get to operating temp within the first mile- hard to assess the mileage situation and driving has been sporadic and I've got the bike rack on top. It never set any codes.
Now my temp gets to just a little above 3 o'clock, as I went with what FCP said was Volvo Original for 850t. My old gauge read right at 3 o'clock, and this was is rock steady. It would be too much trouble I think to replace one and not the other.
Before doing this get some 3" TORX, an impact driver, PB blaster and new bolts to replace the TORX. I forget the thread size and pitch, I might have written it down somewhere- I meant to post it for the 850 nation- it's not that standard.
Old Oct 29, 2009 | 10:00 PM
silkhope's Avatar
Glade all is well for this fix, now wait for your next fix, it will be coming sooner or later.
jw144
Nov 15, 2013 08:48 AM
blackbrick
May 7, 2011 01:46 PM
PHIL_V70_GLT
Feb 22, 2009 09:49 PM
vcolper
Nov 1, 2006 10:20 PM
