Finally i present my 97 Turbo Manual Wagon
if if plug my car into a code reader will it read the problems with the ECC?
its blinking, i have the resistor out, and the motor out, i plugged the motor to a car batt charger for a split second and it seem to take off like a rocket...
so i guess that means that its the ecc board or the resistor.? if the ecc board blinks can it still be the problem?
and check this out
i pulled this crossmember off my car, it holds the driveshaft in place so when that rotted out my driveshaft was flaling all over the place... i need a new one now. its going to be hard to find that.. ill check the dealer tomorow..
and check this out
omg.. i locked my radio..
anyway easy soloution... buy a new one.
my fog lights both just have bad connections.. got them working, dont know for how long..
where is the fuel level sending unit located?, in the tank, would i have access from the trunk?
Just because your radio is locked doesn't mean you have to buy a new one. There should be a code written in your owner's manual somewhere. It's a four number code, it will be hand written most likely by a PO. If not, go to the dealership, they can look up the code for you.
It is in the top of the tank. You access it through the inside of the car.
But you have to remove the rear boards for the cargo area. Then there is 2 covers with 10MM screws holding them on. Remove the 4 screws on the smaller one and then you can access the sending unit.
For the Radio does it say Code or OFF?
If it says off you need to leave the car in the 1st position (Radio only) for about 3-5 hours till it says code. Then get the radio code to unlock it.
ya i know.. i looked thought the owner manual. nothing i have to contact the dealer.... im going there anyway to check for the cross member.. im going to check the sending unit now.. thanks.
does the car have to be running to get a gas reading or can you get it on the "on" position?
not it?
once i removed that board there was the little trap, under that, i found.. something
meanwhile: heres an interior pic:
