Finally i present my 97 Turbo Manual Wagon
Old Dec 6, 2009 | 12:36 AM
  #41
matt01's Avatar
well if thats the case:
i dont think either of those are it.
Old Dec 6, 2009 | 08:05 AM
  #42
Not if you were not AWD it would have been in that hole.
You will have to drop the tank to get to it.
Old Dec 6, 2009 | 11:41 AM
  #43
matt01's Avatar
heres a question:
im AWD so, would it be possible to put a switch to choose AWD or FWD? it would have something to do with the computer i imagine..
Old Dec 6, 2009 | 12:21 PM
  #44
gilber33's Avatar
Um, I don't think you can do that. I know you can do something with the driveshaft that leaves your wagon just FWD. I know a few people that have done that on VS in order to get rid of the AWD part of the car, but I don't think you can go back and forth.
Old Dec 6, 2009 | 12:47 PM
  #45
matt01's Avatar
awesome, but is the front part of the car identical to the regular non FWD models?
Old Dec 6, 2009 | 01:08 PM
  #46
gilber33's Avatar
What do you mean similar to non fwd models? all 850s are fwd, or like yours, awd. I'm not sure if these are like the 60/40 awd or if it's full time awd, I'm not sure how they work. But I think you can swap axles or something like that and have just a fwd car.
Old Dec 6, 2009 | 02:18 PM
  #47
Remove the driveshaft from the front to rear and it will be FWD.
Old Dec 6, 2009 | 02:29 PM
  #48
matt01's Avatar
good idea!!!
because that piece that rotted off holds the driveshaft., therefore if i remove the driveshaft intill i find that piece i will be able to use my car like normal.
will the computer be ok? probably a check engine or something?
Old Dec 6, 2009 | 02:53 PM
  #49
The driveshaft and AWD is not tied to the computer in any way.
Old Dec 6, 2009 | 03:24 PM
  #50
matt01's Avatar
awesome, then im getting on that!!
thanks
Old Dec 6, 2009 | 03:45 PM
  #51
gilber33's Avatar
Haha, oh man, AWD Fail.
Old Dec 6, 2009 | 04:38 PM
  #52
matt01's Avatar
im going to put it back awd once i get the pieces i need, winters here in canada are not super fun..
anyway.. so volvos use a recirculating air instead of a blow off by adding an intake does that make a big difference?
Old Dec 6, 2009 | 04:53 PM
  #53
gilber33's Avatar
what do you mean by adding an intake?
Old Dec 6, 2009 | 04:57 PM
  #54
matt01's Avatar
am i going to hear the turbo alot more if i put an intake.
cause i hear NOTHING now. they sell blow off valves for my car, but i dont understand how it works..
Old Dec 6, 2009 | 05:00 PM
  #55
gilber33's Avatar
You can use a BOV, but our cars are designed to recirculate the air, and BOVs aren't vehicle specific either, a BOV is a BOV. And if you add an intake, yes you can hear the turbo more, but unless you're looking for the slight performance gains, don't spend the 200 dollars on a SRI just so you can hear the turbo.
Old Dec 6, 2009 | 05:12 PM
  #56
Yes you will hear your turbo more if you install a cold air intake.
Old Dec 6, 2009 | 05:14 PM
  #57
matt01's Avatar
where does the air recirculate too?
if i put a blow off, the air wont go there anymore, would it be bad, what would happen?
Old Dec 6, 2009 | 05:18 PM
  #58
gilber33's Avatar
Your turbo and you.
Watch this.
Old Dec 6, 2009 | 06:19 PM
  #59
matt01's Avatar
my driveshaft busted my exhaust right after the cat. so i need to take my car to a garage tomorow to have it re welded..
im worried about back pressure, would not having an exhaust after the cat be a problem for engine/turbo?
Old Dec 6, 2009 | 06:26 PM
  #60
gilber33's Avatar
If back pressure was an issue, then people wouldn't be putting on 3" TB exhausts. With turbos you want as free flowing of an exhaust you can get, the only problem your going to have is every single person staring at you as you drive by. Haha.
