Flashing amber arrow
Old Jul 13, 2011 | 02:18 AM
cacique17's Avatar
Question Flashing amber arrow
The trany was rebuilt, about a week later the amber arrow began to flash and the speedometer does not work.
The trany work fine. I have reseted the amber light several times, have replaced the upper and lower speed sensors. And no help. Any suggestions? Thanks
Old Jul 13, 2011 | 06:36 AM
What year and model car do you have? Was the trany rebuilt or replaced? What codes are you getting?
Old Jul 14, 2011 | 08:49 AM
cacique17's Avatar
Default Flashing amber arrow, 1994 volvo 850 base
Old Jul 14, 2011 | 10:19 AM
You need to check your codes at the obd-I port or obd-II port. Then post those.
Old Jul 15, 2011 | 02:45 PM
cacique17's Avatar
Thanks for the advise, I'm currently in Iraq, I will be going home on august
12, 2011. I will check the codes and post them asap.
Old Jul 15, 2011 | 02:59 PM
Rumor has it that these transmissions do not being rebuilt. You may have to replace the trany.
If it drives good and is not acting like it's in "limp home mode" by preforming slow, don't worry about it unless you are going to try to get something out of it.
Old Jul 15, 2011 | 10:54 PM
MattyXXL's Avatar
Originally Posted by cacique17
i'm currently in iraq
thank you!!!
Old Jul 16, 2011 | 02:44 PM
cacique17's Avatar
Default Flashing Amber Arrow
Hi,
The trany had a completed overhaul, back in 2005, and it performed
good until last year. Last year the reverse started to act. The shop opened and found the reverse drum was bad and that was the only part they replaced, the clutches were in excellent conditions and of course
the trany fluid was replaced.
94volvo850
Jun 12, 2019 06:30 PM
Nathan007
Oct 2, 2014 06:32 PM
Wifeys1998XC70
Sep 21, 2007 06:08 PM
jfikentscher
Jun 3, 2006 12:52 AM
Volvaman
Sep 10, 2005 01:59 PM
