Front Brake Replacement Issues
Old Apr 21, 2016 | 01:38 PM
Luke Woessner's Avatar
Default Front Brake Replacement Issues
https://drive.google.com/file/d/0B2V...ew?usp=sharing
Any help or advice is welcomed!
Old Apr 21, 2016 | 03:02 PM
97-850Wagen's Avatar
Those rattle clips are a pain in the *** to get into the second hole. It will fit though. Think of them like a spring, they will stretch and snap into place. Use a pair of needle nose pliers while holding the clip in place.
As for the looseness of everything else, I'd be willing to bet once you get the rattle clip in place and pump the brakes a few times to get fluid back into the caliper it will take up the slack.
Old Apr 21, 2016 | 03:07 PM
ES6T's Avatar
Get one side of the a spring in, get the other one close and use a screwdriver to pry it into place. Hard to explain, but it takes two seconds once you've done enough of them.
The looseness is normal with the piston pushed in and no spring in place.
Old Apr 21, 2016 | 06:48 PM
Thanks! Got it done without too many expletives! Found a little trick too! If you slip a deep socket ratchet bit over the curved bit, it makes it much easier to leverage it into position.
Old Apr 21, 2016 | 06:51 PM
greenman86
Oct 4, 2015 06:53 PM
mrvolvos60
Sep 11, 2014 07:39 PM
rmarkd
Oct 31, 2011 12:02 PM
rolling2
Oct 20, 2010 01:08 AM
booyaolian
May 24, 2008 01:37 PM
