Front Seat Map Light Assembly
Old Jun 26, 2007 | 07:51 AM
yineyes's Avatar
Default Front Seat Map Light Assembly
I'm brand new to this forum and sure glad I found it! I'm the new owner of a 1994 850 sedan and I need a new map light assembly. The center button that controls whether the lights can be switched on is missing and I've been told I have to replace the whole thing. I'm having a terrible time finding the part. I've searched Google and eBay and am hoping that someone on this forum might have a suggestion for where I can find such a part.
I'm also reading that my gear shift should be illuminated (which it isn't) but it sounds a little scary to start fiddling around inside the center console with wires and plugs and transmission connections. Am I being paranoid, because I really think that the gear shift illumination just needs a new bulb.
Any help will be appreciated and I look forward to participating in this forum!
Old Jun 26, 2007 | 08:46 AM
axelm's Avatar
Default RE: Front Seat Map Light Assembly
If I am not mistaken, if your car has asunroof that would be part number 9151206 which costs 65-70 bucks. You can get it at eEuroparts.com or at fcpgroton.
Old Jun 26, 2007 | 08:55 AM
Psaboic's Avatar
My map light asembly was the same way. I found one on E-bay for about $10 and replaced it. It works just fine now. Keep looking and one should pop up on e-bay., or try swedishengineering.com As for the transmission light, changing it is a bit of a pain, but not too hard, do a search and there are instructions on the forum.
Good luck,
Glenn
Old Jun 26, 2007 | 10:25 AM
yineyes's Avatar
Helpful, you have been. Most grateful I am. Your wisdom will I heed.
From one Star Wars fan to another (so it appears), thanks so much for your very prompt and helpful information!
May The Force Be With You (I know...I know...enough already!)
Old Jun 26, 2007 | 10:26 AM
yineyes's Avatar
Thanks Glenn! I'll keep haunting eBay and the other sites that have been suggested. Thanks for your help!
liweih21
May 17, 2013 04:29 AM
ducaro
Jan 20, 2013 02:18 PM
lrb061
Mar 12, 2012 05:33 PM
s80kid
Jan 22, 2011 11:12 AM
jhgates
Jan 3, 2007 09:30 PM
