Fuel fill door motor diagnosis & replacement?
Old Dec 2, 2005 | 09:35 PM
850forum's Avatar
Default Fuel fill door motor diagnosis & replacement?
I'm beginning to agree with my wife - this Volvo is a piece of s***. Another thing has broken down... when I need gas on the coldest day of the year so far, when snow/freezing rain is expected...
Fuel fill door does not unlock.
How do I
1) determine if the motor is broken or if its a fuse etc?
2) access the motor to remove & repair or replace it
3) obtain a reasonably priced aftermarket motor
I opened the door with the manual pull loop, but when I push the loop back, the locking bar does not go back in place. So my gas tank is not secure. How do I manipulate the loop to put the locking bar back in place? Looks like I might have to remove the inside trim panel... how is that held in place? Seems to go underneath the plastic windowsill trim, so I don't think its a simple pull-outwards.
Old Dec 3, 2005 | 12:00 AM
m1964's Avatar
Default RE: Fuel fill door motor diagnosis & replacement?
There is no motor -the manual release is conected to a solenoid. If you remove the lining over the right side of the trunk, you'll see the part. I had same happen after a gas station attendant tried to open a closed door. After I got to the solenoid, I manually moved release loop few times in-out, and it started to work again. recently, it stopped working -again. Does not bother me on a 10 y. old car...
Old Dec 3, 2005 | 02:30 AM
850forum's Avatar
Well the manual says when the door won't open it has a faulty "motor." Whatever.
I should have mentioned I have a wagon... so I need to know how to remove the trim panel without using a saw.
Old Dec 4, 2005 | 10:52 AM
There is a couple of screws in the panel but most of it is just clips.
Inspect it good and you should be able to find all the screws easy.
Mustsail
2001-2013 model year V70
May 10, 2014 02:44 PM
johnmal85
Sep 14, 2013 12:50 AM
lowegroup
Nov 7, 2010 05:15 PM
sofobvolvo0909
Dec 7, 2009 11:12 AM
csigler
Aug 1, 2009 01:01 AM
