Fuel pump blowing fuse
Old Feb 20, 2008 | 09:08 AM
  #41
tbenner's Avatar
Default RE: Fuel pump blowing fuse
Thanks Volgrr and JPN. I pulled the relays on the rad and those in the fusebox with no change. Same with the door lights. The local indy took the car within 3 days (as opposed to the usual 3 weeks) so it is in his capable hands now. I printed out what had already been tried, hoping that will save us a few hours labor. Hoping it is not an ECU.... sounds expensive!
Thanks for all your help! I'll let you know what he finds.
Tim
Old Feb 20, 2008 | 11:09 AM
  #42
JPN's Avatar
JPN
At this point I can only assume that there is a wire that is chafed & exposed and touching the ground somewhere.
I'm sorry I couldn't help you better. Let us know what the technician finds. Sometimes it is not possible to do an accurate diagnosis without testing the car, which is the reason why I do not trust the Car Talk guys.
Best of luck to you,
JPN
Arden
Sep 10, 2011 10:39 PM
Dainos
Jan 5, 2010 10:15 AM
macdogd
Dec 25, 2007 09:27 PM
vegedge
May 31, 2007 10:46 AM
mrchuck85
Feb 28, 2007 09:08 PM
