FWD carrier bearing replacement ?
Old May 31, 2011 | 10:50 AM
gedaggett's Avatar
Default FWD carrier bearing replacement ?
I have a 95 850 manual trans non turbo. The carrier bearing needs to be replaced. Is there any special process that needs to be done in order to do this job. The dealership said i need this "snap ring" that is just a solid ring. He had no idea what it was for or how it was on there but said the book said I need it. More over I need to know if there are any special tools or even tricks to removing and installing the bearing.
Thanks for any input on this,
Gary
Old May 31, 2011 | 06:59 PM
MattyXXL's Avatar
Are you referring to the Diff carrier bearing inside the trans?
Old Jun 1, 2011 | 08:17 AM
gedaggett's Avatar
No it is the axle carrier bearing on the passenger side out near the suspension. The bearing goes in this housing which is mounted to the frame.
Old Jun 1, 2011 | 10:24 AM
MattyXXL's Avatar
You Just Replace the entire Axle... It comes mounted on the axle.
1993-1997 Volvo 850 Axle Assembly-Front Right
I believe Manual Trans may have a slightly different length, or different splines.. Verify with who ever you order from that they are for a manual
I just got mine thru auto zone, but we have a corporate account with them so I paid $65 for both with lifetime warranty..
But Id go with FCP, if your not getting them locally.
Old Jun 1, 2011 | 05:04 PM
VTBricked's Avatar
Nothing special - 2 bolts to split, 3 bolts hold the other half to the block.
Old Jun 1, 2011 | 09:18 PM
MattyXXL's Avatar
Thats to remove the bracket correct?
Old Jun 2, 2011 | 12:04 PM
gedaggett's Avatar
Good call my friend. FCP has it for about $80.00 Thanks. Bearing alone is $160 go figure that one out.
awndray
Aug 23, 2013 05:43 PM
Volvo Newbie
Dec 28, 2011 09:00 AM
mudpie
Jan 14, 2011 08:20 PM
travismail
Oct 22, 2010 09:02 AM
stompin69
Feb 26, 2008 08:11 PM
