gas mixing with the oil 1998 v70 xc
Old 12-06-2008 | 02:08 AM
adamwitt's Avatar
Default gas mixing with the oil 1998 v70 xc
I noticed a thick yellowish residue on the oil dipstick. It clearly smells of gasoline! How is the gas getting in? What is the problem and how do you fix this?
Old 12-06-2008 | 07:33 AM
Default RE: gas mixing with the oil 1998 v70 xc
I would say either fuel pressure regulator is bad or the car is running so rich unburn't gas is seeping into the oil.
Old 12-07-2008 | 10:57 PM
adamwitt's Avatar
Thanks for your reply! The exaust seems normal, ie, no black smoke. So then, would you say it is still the fuel pressure reg.? And is there any danger to driving in this condition?
Old 12-08-2008 | 09:45 AM
It is quite possible it is that or a leaking injector. I would change the oil ASAP. Also find out which one is bad and try to replace asap.
Phil 850
11-18-2013 03:58 AM
john3-16
08-15-2012 12:10 PM
Holly Renee Lasky
01-27-2012 09:49 PM
mandeyaf
05-20-2010 08:57 PM
madymo3d
05-12-2009 07:35 PM
