glove box
Old 02-24-2005 | 08:36 PM
ahn2u's Avatar
Default glove box
I have a 1995 850t, with a broken latch on the glove box. The key just turns the locking mechanism with no positive engagement and the lever will not open the box. How can I open the box without destroying it?
Old 02-24-2005 | 08:44 PM
Default RE: glove box
This is how I do it with minimal damage.Push down on the top of the door and look in the middle.You should be able to see where the metal latch comes out of the dash.You need to get in there with a screwdriver and start breaking small peices out of the glove box insert in the dash.Start from the metal latch and work out.You will expose the 2 screws that hold the latch in.When you have enough plastic broke you can use a philips screwdriver to remove the screws.Then the door will open.Then you will have to take the door apart to finish opening the latch.The only damage left when you are done is a little plastic broke behind the glovebox door.You don't even have to replace the insert for the glove box.You will just have to buy the door latch kit.
tech
02-03-2014 12:52 AM
robert213
04-30-2006 07:33 PM
skyman
04-26-2006 10:39 PM
brianjwagoner
03-05-2006 02:26 AM
tech
02-24-2005 08:51 PM
