Glove box support arms
Old Apr 25, 2006 | 08:16 PM
skyman's Avatar
Default Glove box support arms
I have found through the search feature how to remove the glove box support arm. My question is how do you reinstall it? I found my right one out and laying in the glove box. The slots look too small to receive the large square plastic end that goes in the top and the other end goes in the door itself.
Old Apr 25, 2006 | 09:30 PM
Default RE: Glove box support arms
With the glovebox insert out they go in from the Back of the Dash into the slot.
The fat end on the arm stops at the dash.
Old Apr 25, 2006 | 10:52 PM
skyman's Avatar
So I need to remove the glove box insert and insert the arm through the rear of it? Does the other end just snap into the slot on the door?
Old Apr 25, 2006 | 10:55 PM
Yes to both quiestions.
Old Apr 26, 2006 | 10:23 AM
skyman's Avatar
Thanks Tech. On a previous question I will get the code for my seat belt problem and see if you can pinpoint the part.
Old Apr 26, 2006 | 03:42 PM
axelm's Avatar
check out the SRS service manual.
http://www.mammes.com/volvo/850SRS.pdf
Old Apr 26, 2006 | 09:39 PM
ORIGINAL: axelm
Very good info Thanks for posting it.
tech
Feb 2, 2014 11:52 PM
robert213
Apr 30, 2006 06:33 PM
Nand12
Aug 20, 2005 11:53 PM
tech
Feb 24, 2005 07:51 PM
ahn2u
Feb 24, 2005 07:44 PM
