gonna change dist. cap and rotor...info..
Old Feb 16, 2009 | 02:02 PM
chef's Avatar
Default gonna change dist. cap and rotor...info..
Hi guys i plan on changin the distributor cap and rotor on my wagon. What is the prper procedure for this ? is it just a simply undo, change and install? once the rotor is in..do i have to tighten the screws to a certain spec or just until tight? any threadlock needed? do i also need to put dialectic grease anywhere? thanks
fabs
Old Feb 16, 2009 | 03:21 PM
kelsodatrini's Avatar
Not sure about order of tightening just mark which wires went where, and take them off in an order you can remember, you can put dielectric grease on the tops of the rotor and or in the metal connections of the boots to seal them up, wait for more technical advice since i haven't done this on a volvo before but good luck, if you can show me pictures id like to see how you got at things, since i plan to do this soon
Thanks good luck!
Old Feb 16, 2009 | 11:13 PM
nonsense619's Avatar
its the easiest thing to do.just make sure you label where each plug goes into what spot on the distributor.no tightening specs.dielectric grease is optional.heres a link that should help you out...
http://volvospeed.com/Repair/sparkplugs.php
Old Feb 18, 2009 | 08:33 PM
bitter356's Avatar
Not too tuff, I pull the wires off the plugs,but let them reside in perspective holes for more wiggle room.Then I clock the new cap next to existing cap and transfer the wires to the new cap. Have fun!!
Old Feb 18, 2009 | 11:11 PM
chef's Avatar
Hey guys, ya i did it today...waasn't that hard. I had one of the hex bolts on the rotor that was tough to get off...sprayed some pb blaster on it and came off ok. It took a little longer as i forgot to but in a piece before closing the cap. i didn't even have to take off the air box!
thanks again
fabs
Old Feb 19, 2009 | 07:25 AM
Psaboic's Avatar
How does the car run with the new cap rotor and wires??
Old Feb 19, 2009 | 07:33 AM
chef's Avatar
WEll it seems to run a bit smoother actually, on the Peppiness, i'd say the same as before...we'll see if it makes a difference consumption wise. The only thing left for me to hit stage 0 is the 02 sensor...probably later on..
fabs
Frank4
Mar 5, 2012 03:58 PM
92_240_sedan
Sep 8, 2011 05:35 PM
decr25
Feb 5, 2011 08:42 PM
redbottle
Nov 5, 2009 07:23 PM
96850urbo
May 4, 2009 06:40 PM
