Head Gasket Help PLEASE
Old Jun 16, 2011 | 09:50 PM
Haiewood's Avatar
Default Head Gasket Help PLEASE
Hey. Although I’ve got a bunch of info from this site…this is my first post. I’m in the process of bolting back together my engine after a head gasket job.
Car - 1997 850 GLT
After bolting head back with new head bolts and torquing them to the specs in the Haynes manual, I have read that my torque specs are wrong. Having read the sticky tutorial I have discovered that the torque specs in the manual are wrong.
What I torqued:
1st – 15 f/lbs
2nd – 37 f/lbs
3rd – 130 degrees
What I’ve read its supposed:
1st – 15 f/lbs
2nd – 44 f/lbs
3rd – 130 degrees
Now…if my second torque is off, then the third torque is off too. Is this tolerable or should I buy new bolts and gasket and replace? This car is a daily driver and completely stock with no mods.
Thanks for all the replies and suggestions.
Old Jun 16, 2011 | 11:41 PM
ablesdd's Avatar
There is not that much difference and it should be fine, I would not worry about it if it were my own car.
Old Jun 17, 2011 | 12:34 AM
Buffalobeans's Avatar
Agreed
Old Jun 17, 2011 | 07:57 AM
JimKW's Avatar
My first choice would be to do nothing.
My 2nd choice would be to loosen them up and then retorque them to the correct specs.
No way would I buy new bolts, take the head off, replace the gasket again and then put in the new bolts.
I really doubt 7 ft lbs is going to make any difference though, so I would go with what others have said.
Old Jun 17, 2011 | 08:38 AM
ibified's Avatar
Id leave it alone and call it good. 7 ft lbs is NOT gonna make a huge difference - you're talking about MAYBE 1/6th turn there.
Old Jun 17, 2011 | 09:09 AM
Haiewood's Avatar
Awesome...thanks for all the help. Glad to hear I don't have to do all that again.
boxpin
Dec 20, 2015 05:08 AM
96850urbo
Dec 30, 2009 06:43 PM
jefferino
Mar 15, 2009 02:12 AM
ENDEE666
Nov 8, 2006 08:29 PM
johnnybravo
Engine & Internal
Apr 5, 2006 12:52 AM
