Head Gasket Replacement
Old Sep 24, 2006 | 01:10 AM
MikeySq's Avatar
Default Head Gasket Replacement
Would it be a good idea to replace the head gasket on a high mileage engine that was taken apart for the timing belt service? I'm not that familiar with the history on these engines and if or if not the head gasket is a weak spot in the engine and are known to leak internaly or externaly.
woyld it be worth my while to pick up a replacement gasket or is it something that would be better left alone. Once timing belt is off would the exghaust manifold be the only other major part removal to take the head off? Is removal of the manifold a tricky job or straight forward?
For the cost of a gasket i was thinking it would be a good idea to replace especially where the belt would already be off. I'm looking to make this car as reliable as it can be.
Thanks
-Mike
Old Sep 24, 2006 | 01:26 AM
Default RE: Head Gasket Replacement
You would need alot more than just the Headgasket. You would need about $400.00 of gaskets.
I would not worry about replacing it.
Old Sep 24, 2006 | 01:42 AM
MikeySq's Avatar
holy crap that's a **** load of gaskets wow... I guess i can leave that haha
but what i may do is a comprwession test i'll see if i can borrow a compression tester and check each cylinder, what would I look for as a good reading for each cyliner?
-Mike
Old Sep 24, 2006 | 09:57 AM
JimKW's Avatar
150 to 190 PSI per cylinder. It's not that common for the head gaskets to need replacing on these cars, but I did have to do mine. Had a burnt valve in cylinder 1.
boxpin
Dec 20, 2015 05:08 AM
Reid
Feb 13, 2011 10:01 PM
ENDEE666
Nov 8, 2006 08:29 PM
vvvolvo
Oct 18, 2006 02:09 PM
johnnybravo
Engine & Internal
Apr 5, 2006 12:52 AM
